HELP - Sony MZ-R55 wont respond...
jedi-knight83
Hi,
i have a sony MZ-R55. i was listening to track 2 when the battery went flat and the unit stoped. i swaped to my second battery and now the unit will not respond atall. when i put a disk in and close the case the spinning disc icon is shown but after about a minute it says 'disc error' and then if i open and close again it says 'no disk'.
i have tried leaving the battery out for a few minutes but its doesnt help.
its almost like it needs a reset???
help please!
thanks
right, i downloaded the service manual and was having a go with the settings.
if i go into the settings and press the 'track back' button it goes into the (assy mode) and i can hear the laser moving. then i disconnect the power and try the disc and it works. if i then remove the disc and then put it back and try again, it doesnt work again...... mad.gif
Easy there tiger. I deleted your "bumps" to this thread. Welcome to the forums, btw - please don't do this again. :sleep:
Sounds like your unit may be done. I've heard of similiar issues and repair was the last option - but I would honestly try operating the unit without battery and just a straight AC connection and see if it'll operate. You may also want to let it rest for a day or so and then try it out.
