rev aaron Posted April 9, 2004 Report Share Posted April 9, 2004 ok, i work at WUNH 91.3FM in the usa. I need a product that allowes me to transfer back and forth from our computer to a minidisc. whether this is a md2-pcs sony thing or whatever. the discs then need to be played in a regular DENON md-auto player. any help would rule, thanks. we've been using mds for years now, but all the old ones are crapping out on us and it's a bit difficult to copy them over. tia Quote Link to comment Share on other sites More sharing options...
Christopher Posted April 9, 2004 Report Share Posted April 9, 2004 Welcome to the forums - please try not to double post in the future. :sleep: Okay, so you want to transfer recordings from the MD player and recordings done on the computer to the MD player in a faster-than-realtime scenario? If so, then you'll most likely be content going down the Hi-MD route. What's your budget? Quote Link to comment Share on other sites More sharing options...
rev aaron Posted July 12, 2004 Author Report Share Posted July 12, 2004 I already have 2 industrial MDs and I need to do the transfering of tracks so those players can play the mds. $$ isn't necesarily a problem. if it's a few thousand, that might be a bit harder to swing. Quote Link to comment Share on other sites More sharing options...
