Mac-Software for NetMD MZ-N910
mampfi
Nope. Sony doesn't make NetMD software for Macintosh [yet]. Your best bet if you want to use NetMD would be to boot into OS9 [not classic] and run VirtualPC with a compatible version of Windows, and then NetMD software inside of that. It's been said to work, but I haven't tested it yet on my old iBook.
Either that, or, you could get an optical out device like the Xitel MD-Port I/O or some other external soundcard solution which has optical out so you can transfer to your N910 in real-time by playing back the files in iTunes or whatever media player you use.
Thanks, I thought, that it would be like that. Perhaps I try to install the Sony Software in Virtual PC under Mac OS X on my PowerBook. And with a little help from my "Windows" I can transport audio-files to my NetMD. If thats not possible, I have another reason for using my good old PC.
Thanks and have a nice easter weekend, good luck in searching "big" eggs, Manfred
