Help! Sony MZ-n10
warejouse13
I have a N707 so it might be different on the n10 but what I do is when I'm going to record something I hold down pause and slide over record. It should be on record pause now. Then I click menu and navigate down to record volume then click enter. It will be on auto and you want to be on manual. Select manual. Now your forward and reverse buttons will adjust your record volume. Also remember to set your headset volume at an expectable level. Hope this helps. Let me know if you have more questions or this doesn't make any sense.
Thanks :grin:
