Minidisc and Mac--HELP
briantreanor
Hey folks. After much thought, I am ready to throw down the cash for an MD. I would like to get a Sony MZ-NHF800, however... I am also getting a new laptop this summer and for a variety of reasons too lengthy to go into here, I have decided to go with an Apple 12" Powerbook.
So... I guess I have a problem. Is there ANY way for me to get the MZ-NHF800 to be compatible with a Mac? ANY way? I really would like this combination as I have come to the conclusion that Ipods suck (for me) and PC computers suck (again, for me).
I am definitely not as hack-savy as many folks on this site, but I am willing to go to some lengths to make this work. Any help would be appreciated.
Brian
PS--OK, If it helps...
The reason I want the MZNHF800 is (1) 1GB disks, (2) much longer battery power than an Ipod (for use on backpacking trips), (3) the ability to record things off the web via the optical cable (my understanding is that this will allow real time recording of any sound made by the computer), (4) AM/FM so I can listen to NPR while I ride my bike to work in the morning.
The reason I want a Powerbook is (1) less problems with viruses corrupting the book I am working on, (2) photo and video editing (I'm an amature here), (3) Ichat use for speaking to relatives overseas...
Again, thanks for any help that may be offered.
I'm thinking that using Microsoft Virtual PC for the MAC platform MIGHT help you there. It is software that allows you to run Windows inside a window on your MAC. You might be able to install Sonic Stage and manage music on the MD unit with it.
I don't know what you should exepct for playback capabilities for Virtual PC though. Usually virtual machines suck or just don't work for playing music. I know that is the case for another product for PCs (VMware) that lets us run another operating system in Windows or Linux.
My wife has a Mac running OSX, but the thought never occurred to me that I might want to manage MDs on it. I have a pretty decked out PC, so I never thought about it much.
Anyway, you might want to investigate the use of Virtual PC for MAC.
I took the liberty of checking the Compusa website from my area (can't think of another place here that sells MACs). It even looks like they will give you the option to buy it with Windows XP Pro preinstalled, so that you dont have to install it on Virtual PC. Either that, or you can buy the standalone one and install Windows XP or whatever you want to try on it, which is cheaper if you already have an XP license.
Here are some prices I found:
Virtual PC for Mac 6.1 with Windows XP Professional (Mac)
Product Number:305534
Brand: Microsoft $249.99
Virtual PC 2004 (PC)
Product Number:50342949
Brand: Microsoft $120.54
I hope that is something that might work for you. I don't see why you couldn't use Sonic Stage on it and manage the MD recorder over USB with it since Virtual PC supports USB connectivity.
-Ice-
