How do I 'Check-In' music from my minidisc to my computer?
djsteen
I'm using Sonic Stage 1.5 and I've tried just dragging it over but it says there was an error in the transfer. :wacky: Is there a way do copy it over? Are there different programs? I'm a bit of a newbie to NetMD, but I've had a recordable minidisc since 2000.
I have a line out on my MZ-R900, would that be the digital out I need? I have a thing that goes from USB then to a little box and that converts it to an optical cable port and then to the MD unit, They can go back and forth to the computer but you use the program it comes with to put the music onto the computer right?
I hope this makes sense. unsure.gif Thanks heaps! :grin:
I am very familiar with the device you're talking about, as I own one myself. Unfortunately, this device only transmits information one way, and that's to the MD unit. For best analog results you can use line out, with a male to male analog stereo cable; one end in the line out [aka headphone jack], and the other end in your "mic in" on your computer.
