SI: VAIO Mouse VGP-BMS10 Pictorial
DSC_0026
Well it did not take long for SonyStyle to send me a new VAIO Bluetooth Laser mouse we have written about earlier. I thought I would post some pics and share some deets on this well designed, ergonomic mouse thanks to its optimal size and weight for mobility with a design that fits snugly in your hand.
The build is pretty good and the sliding cover works great, sorta reminds me of my SE XPERIA. The aluminum brushed metal cover really stands out. I just thought that a Sony VAIO notebook with such coating would be a gem! It will definitely match my VAIO X505SP model as the top of it has the noticeable threads of carbon fiber and the sliding cover of VGP-BMS10 has a hair-line etched aluminum finish. Closing the sliding cover turns power ON and OFF. The light indicator will let you know when you 2 AAA batteries need to be replaced (Sony did include 2 AAA batteries).
Here are some specs:
Buttons/Wheel: 2 buttons/ 1 wheel
Position tracking method: Laser sensor
Sensor Resolution: 300 dot/cm (800 dpi)
Communication method: Bluetooth Standard 2.0
Communication distance: 10 m (32 ft.)
Frequency band: 2.4 GHz
Battery life: Approx. 1.5 months
Mass: 90 g (3.2 oz)
Conclusion: all in all it is a pretty sweet, cool looking mouse. Available now at SonyStyle.com
Check out the Pictorial Below:
DSC_0022
DSC_0023
DSC_0024
DSC_0025
DSC_0027
DSC_0028
DSC_0029
DSC_0030
DSC_0031
DSC_0032
DSC_0033
DSC_0034
DSC_0035
DSC_0037
DSC_0039
1 answer to this question
