n10 problem :(
Humgaorange
Hi everyone, i have my n10 almost a year now. Today, while i was surfing the net for like 3 hours, and then suddently my n10 stopped, it didn't show (PC -> MD) words on my MD screen.
And i checked my device manager, and it said "This device cannot start. (Code 10)". I tried to reinstall the driver, and the SonicStage software, but it didn't work. I tried to unplug and replug the USB port, and it didn't work also. Lastly i even tried just to plug the usb port directly into my N10, but failed.
When I pressed the Stop button on my MD while it's connecting to do cradle, it worked (PC -> MD), but I can't burn my mp3 !! I can see all my songs on my SonicStage though, i just can't delete and burn new songs.
Do you guys think is my MD problem or my computer??
I am using Windows 2000 Professional (Which support N10), Pentium 3 800Mhz, 128 SDRAM and i do have the latest service pack. Can someone please help me
Welcome to the forums! ^^
1. Uninstall all OpenMG related software via the Add/Remove Programs control panel and reboot as necessary. This means, OpenMG 2.2, related 'Limited Patches' and the 'Secure Module', SonicStage, Simple Burner, and RealOne. Make sure that you unplug your unit.
2. If you run Windows XP, proceed to delete directories within 'Program FilesAll UsersApplication DataSony Corporation' 'Program FilesCommon FilesSony Shared' 'Program FilesSony' relating to OpenMG.
3. Start -> Run -> regedit. The 'Registry Editor' utility should appear on your screen. Delete the references to OpenMG located under 'HKEY_CURRENT_USERSoftwareSony Corporation' and 'HKEY_LOCAL_MACHINESoftwareSony Corporation' by right-clicking on the entries.
4. Download the newest versions of the NetMD software. After installation, start the software and plug in your unit.
Download the latest version of Sonicstage here:
http://forums.minidisc.org/viewtopic.php?t=4210
Hey Kurisu, Thx for your reply, I am using Windows 2000 Professional
My MD won't even recognize my driver anymore, I even tried to go to the Device Manager -> NetMD USB - > Driver Tab -> Update Driver -> Display a list ~ -> Click on Have Disk -> Browse Disc Drive -> Select NETMDUSB.Inf -> Ok -> Restart
That didn't work ...
I doubt is my comp, because i tried to do it on my sister's comp and failed also. She has a Sony NE410 model, but i do believe the driver is the same... i am still under warranty, i hope they know how to fix it. sad.gif
