Patchouli Posted April 27, 2004 Report Share Posted April 27, 2004 Before I go by the Sony store and smash thousands of dollars of equipment, what can you do to erase these stupid discs? The computer that made them has long since been retired, the drive reformatted many moons ago. There is no way to check them in. HOW DARE THEY try to control us in this fashion? It's only one box of discs. $15 or so. But I might have to mangle someone over this. I'm going to Super Crazy Glue them to 550 Madison's front door (Sony's HQ) if I cannot blank them. There must be some service mode trick to get the damn thing to ignore the protect bit?????? Can I blank them in some other manufacturer's unit? I'll carry them to a store and "test" a floor model to erase them, if possible. I guess I won't glue them. It won't anger anyone but the poor building super who has to get some guy to remove them. Sony doesn't care. Sony has never cared about it's users. Sony employees will laugh about it. I should beat them. I should beat them all. Quote Link to comment Share on other sites More sharing options...
Christopher Posted April 27, 2004 Report Share Posted April 27, 2004 Easy there. :sleep: It is indeed a pain to try and erase these discs that cannot unless you have a NetMD unit, but I will note that some decks and bookshelf systems can defeat this and erase the discs. What equipments do you have? Quote Link to comment Share on other sites More sharing options...
