ATRAC3 VS MP3
You can find an evaluation between ATRAC, MP3 and WMA in the following pages:
www.sony.net/Products/ATRAC3/tech/lab/TESTfactory_Listening_test.pdf
www.minidisc.org/keep/TESTfactory_Listening_test.pdf
I make a summary of the pdf for the people who use a finder and need to find that information:
Listening Test Report
For Ingenieurbüro Meter Bengel (IPB)
Turnhallestraße 7A, 70565 Stuttgart
ATRAC3plus and ATRAC3 comparison type 1 to type 4
Type 1: ATRAC3plus 48kbps vs. MP3 48kbps and WMA 48kbps
Type 2: ATRAC3plus 64kbps vs. MP3 64kbps and WMA 64kbps
Type 3: ATRAC3 132kbps vs. MP3 128kbps and WMA 128kbps
Type 4: ATRAC3plus 64kbps vs. MP3 128kbps
Used Equipment for listening test:
Equipment
Test CD:IPB
Amplifier:Sony VA333ES
DVD-Player:T&A DVD1230
Headphones:Sony MDRCD3000
Evaluation of the listening test:
ATRAC3plus 48kbps vs. MP3 48kbps: MP3 performs really bad compared to ATRAC3plus
ATRAC3plus 64kbps vs. MP3 64kbps: MP3 again performs really bad compared to ATRAC3plus
ATRAC3plus 48kbps vs. WMA 48kbps: ATRAC3plus shows clearly a better rating compared to WMA
ATRAC3plus 64kbps vs. WMA 64kbps: ATRAC3plus agains shows clearly a better rating compared to WMA
ATRAC3 132kbps vs. WMA 128kbps: ATRAC3 shows only a slightly better rating compared to WMA
ATRAC3 132kbps vs. MP3 128kbps: ATRAC3 shows a small advantage over MP3
ATRAC3PLUS 64kbps vs. MP3 128kbps: ATRAC3plus 64kbps shows almost equal quality of sound reproduction as MP3 128kbps
Guest NRen2k5
Very good!
It's important to note, however, that Lame may perform better at 128kbps than the Fraunhofer encoder used in this series of comparisons.
Aside from that, it was carried out very well and I must agree that for <128kbps, a Fraunhofer encoder would be the best representative for MP3.
My English is very bad, but I am going to make me understand. MP3-Fraunhofer is a coder created by a company for Microsoft for its format RIFF, it is a MP3 to which its extension is changed. MP3-LAME has an algorithm dedicated to "Joint Stereo" of a MP3. MP3-LAME is a little better, but you must consider the speed with which codifies a file. When codifying a file to "MP3-LAME 48kbps" we have a file with low quality. When codifying a file to "MP3-Fraunhofer 48kbps" we have a file of low quality but with emphasis in the high sounds. I suppose that they chose to the format that is approached to the quality of CD.
A very important aspect is the time that take in codifying file MP3. Fraunhofer takes less time than MP3-LAME in codifying a file,
And "Sonicstage2,0(ATRAC)" coder takes less time than the others, in equal conditions of bitreat. It is not that ATRAC is a wonder, but to codify thousands of archives would be a nightmare. :wacky:
