This way to get MD Simple Burner 2.0 works?
Malow
hi, i was looking for simple burner, and after a search, i see no download link to SB 2.0. i look into support section of MZ-N420D (i have a 410) and i found a update to SB 2.0.
ftp://ftp.ita.sel.sony.com/ccpg/portable/...E_MDSB2001U.EXE
i get this update, and unpack with winzip (right click, extract to.) . if u delete the file "InstMdsb.exe" the update will install whitout the 2.0 version installed. it works without conflicts with SS 2.0 (SB 1.1 give me problems whit SS2.0) but, im whitout my netmd here, so, i cant test to see if it works 100%, transfer, e etc...
so... someone can see if this thing works? i belive almost no one get SB 2.0 yet.
(sorry for my bad english, im brazilian)
Malow,
This works for me and I have just tested it with my MZ-N910, both with a CD and also using an Image file created with Nero.
I expect that SB 2.0 will become more available now that the first Hi-MD is available in the US.
If anyone else wants to try this then don't forget to shut down after installing or SB does connect to CDDB. It also only allows transfer in LP2 and LP4 modes, as before, but also will allow for Hi-MD (SP, LP and 48kbps) but I assume this is only when a Hi-MD recorder is attached.
Don't worry about your English it's good enough!
Out of interest can you post a link to the thread full SB2.0, as I cannot find it.
Thank you.
As for the minidisc forum, send a e-mail to the T-Board Administrator which you can find bottom of the first page. I had similar problem a few weeks back after updating my profile and this is how I managed to get back in.
