origami Posted May 16, 2004 Report Share Posted May 16, 2004 Hi. I'm a newbie. I need help with SonicStage installed on Windows 2000 Professional. I used to have SonicStage v1.5 installed. It used to work. Then suddenly it had errors saying can't find database file. then I clikced ok to copy a new blank database file. Then it just freezed. Then I installed SonicStage v2. It had the same problem. The difference is whenever I clicked on ok to copy a new blank database, it closes by itself. Please I need help on this. But the SonicStage v2 works on my Windows XP Home edition on my laptop. Thanks Quote Link to comment Share on other sites More sharing options...
Christopher Posted May 17, 2004 Report Share Posted May 17, 2004 Hiya, and welcome. :happy: This is a software issue, so I will transfer this topic to NetMD. I want you to follow the exact directions within the NetMD FAQ thread and uninstall exactly how it prescribes. After that, install Sonicstage 2 only and reboot after the installation. Write back with your progress.. Quote Link to comment Share on other sites More sharing options...
origami Posted May 18, 2004 Author Report Share Posted May 18, 2004 Hiya. I followed step by step in the FAO page. It still doesn't work. It keeps saying can't find database. Then it goes to ask do you want to copy a new blank datase? I pressed yes. Then it closed by itself. What should I do? Quote Link to comment Share on other sites More sharing options...
Christopher Posted May 18, 2004 Report Share Posted May 18, 2004 A wise man told me that you may have not restarted after the installation. Also, if that is not true, please download this file, reboot, and try again. Quote Link to comment Share on other sites More sharing options...
origami Posted May 18, 2004 Author Report Share Posted May 18, 2004 :ohmy: OMG! Holly Macaroni. The program works! THANK YOU!!!!! The file really made it work. PS = I did restart my computer after installing. Quote Link to comment Share on other sites More sharing options...
Chief Posted June 2, 2004 Report Share Posted June 2, 2004 Quote Hiya, and welcome. :happy: This is a software issue, so I will transfer this topic to NetMD. I want you to follow the exact directions within the NetMD FAQ thread and uninstall exactly how it prescribes. After that, install Sonicstage 2 only and reboot after the installation. Write back with your progress.. I have the same prob. Sonicstage crashed while trying to copy some mp3s to Minidisc. When I try to install it tells me the database is corrupted or is missing. I have tried to install re-install multiple times without success. BTW what file(s) is the "database" in. Any help would be appreciated. I'm using my son's laptop to copy songs now. TIA Quote Link to comment Share on other sites More sharing options...
Christopher Posted June 2, 2004 Report Share Posted June 2, 2004 Did you download the file that I linked to? I think you need to re-reread everything I've said in this thread. Quote Link to comment Share on other sites More sharing options...
