Choosing a Sony Net MD
gabsdad98
I take the train a lot so I'm interested in a Sony MD-Unit to take along with me. All I am interested in is ripping CD's and downloading MP3's. The price ranges I've found run from 80 bucks (Wal Mart) to 300 (Circuit City). So...would I be happy getting a basic unit or are there reasons to go for some of the mid-to-high priced ones? For those that respond, could you also tell me which unit you have? Thanks!
Lemme see:
NetMD only units (usually denoted by the letter D in the end of the model, like MZ-N420D or MZ-NF520D) only allow for downloading from your PC to your MD in LP2 and LP4 mode. I'd just as well stay away from them if I can help it, more on that later.
There are still several "last generation" NetMD/MDLP player recorders, the S2 model, the N510/NF610 family and the NF810/N10 family of models. These models have more of the advanced features, such as recording via line-in or optical-in, remote capabilites, AM/FM/TV Tuner, 6-band equalizer, etc.
The S2 model lacks any remote capabilites and does not have tuner either. However, it retains NetMD download function and can record via line-in, IIRC. The unit is constructed of heavy duty plastic and is beloved referred to as "the tank" for the obvious reasons. If you're the active type or the clumsy type, see if you can still net this model, <$100 nowadays.
The 510 and the 610 is for all intents and purposes the same, except the latter can use the AM/FM/TV Tuner remote. However, the 510 comes with lot more accessories (car kit, a pleather carrying case) for cheaper price. The 510 should run about $100 or less, the 610 $150 or less, provided that you can find them.
At the top of the line there are the 810 and the N10 model. 810 comes with the car kit, N10 does not. Both are of full metal construction, have mic-in port along with line in. They have 6-band equalizer and virtual surround thingy (where as the other models do not). 810 has the AM/FM tuner remtoe, the N10 does not. N10 is the smaller and sleeker of the two models, as it should be since it is the top of the line. If you can find them, the 810 should run you anywhere between $200-$250. The N10, probably more expensive than 810 but you could probably find a pretty good deal for it.
Finally, the MZ-NH600D functions much like NetMD only players, that you can only download MP3s on it and ripping CDs via SimpleBurner. However, I'd recommend this unit over any NetMD out there for the fact that this is a HiMD unit. That is, it comes with 1GB HiMD Disc, so you can store from 10 hours to 40 hours of music on one 1GB disc (or 2 to 10 hours on one regular MD disc reformatted to HiMD Disc). HiMD units also function as a removable drive if needed in a pinch.
Remember that if you want to download MP3s on to your NetMD, you have to use SonicStage or Nero/SimpleBurner method! Neither NetMD nor HiMD can play MP3s natively.
