Can I record over 80 minutes LIVE with NetMD
retroicon
You sure can! If it's a music show, LP2 works just fine--I've used it with great results, and that 2 1/2 hours really helps. I wouldn't recommend LP4 for anything but voice, though (like spoken word shows or school lectures).
If you are recording a long live program, too, you may want to set the machine to insert track marks every five or ten minutes (Auto Track Mark should be a menu item)--this will help you navigate the disc until you have time to manually insert track marks.
Welcome to the forum, Gary!
