AllanH Posted May 30, 2004 Report Share Posted May 30, 2004 I record from microphone using an exterrnal pre-amp/ADC [Deneke AD-20]. With Hi-MD, will I 1) - be able to record to Hi-MD minidisk in PCM format 16bit/44.1 KHz using the optical input? {Yes, I guess) and 2) - be able to transfer the resulting track from the Hi-MD Minidisk recorder into my PC and store as a WAV.file? My ADC sets SCMS to 00 (ie off). I'd like to use Hi-MD Minidisk as a small high quality recoding system, but I don't want to fall into a trap and not be able to transfer my recordings digitally. Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted May 30, 2004 Report Share Posted May 30, 2004 1) Yes. 2) Yes, with a uncertainty. When playing back, the sound is also played via USB. You are able to record that with a suitable software, e.g. CoolEdit. Upload via USB is also possible, but since noone has a recording Hi-MD yet, the export function couldn't be verified fully. But to be frank, upload without export function would be braindead... I say, watch this Forum for further info. Quote Link to comment Share on other sites More sharing options...
