CAFC Posted June 3, 2004 Report Share Posted June 3, 2004 I want to record live music but every time i record it only records to the left side or my earphones when i play it back, you can only hear the right side vaguely. I'm using a sony MZ-N710, with a hitachi HMP 606 Microphone Any ideas on how to record equally into both ears? Thanks Tom :grin: Quote Link to comment Share on other sites More sharing options...
A440 Posted June 5, 2004 Report Share Posted June 5, 2004 You must be using a mono mic. See if it has one ring or two on the plug--compare it to your stereo headphone plug (or the pic under A440 here). One is mono--it's only going in one channel. Get a stereo mic and your problem will be solved. If it is a stereo mic then there's a problem with your mic jack. Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted June 5, 2004 Report Share Posted June 5, 2004 If it's a stereo mic, make sure the jack is pushed all the way into the mic input socket. If it's a mono mic, you can still record equally into both channels using the mono recording mode of your N710. Quote Link to comment Share on other sites More sharing options...
BJ Posted June 7, 2004 Report Share Posted June 7, 2004 I think the HMP 606 is a mono mic (from what I could dig up on the web, anyway). So recording in Mono mode will solve your problem--and double your record time! Bonus! Quote Link to comment Share on other sites More sharing options...
