mmp64 Posted June 5, 2004 Report Share Posted June 5, 2004 I am having MAJOR problems with both SS2 and Simple Burner, using my new 600D. Anyone else experiencing any of these: 1) SS2 locks up when formatting a "standard" MD as Hi-MD; 2) SS2 locks up when transferring tracks to a disc in Hi-MD mode; 3) Simple Burner locks up when transferring. I resinstalled but to no avail. I have a new PC - Pentium 4 with 1 GB of RAM. I never had these problems with SS 1.5 and NetMDs. I'm about ready to cancel my pre-order for the 900 and give up on MD period, though I've been a heavy user for 5+ years. I have no patience for poorly QA'd software. Quote Link to comment Share on other sites More sharing options...
mmp64 Posted June 5, 2004 Author Report Share Posted June 5, 2004 I may have solved one problem - by disconnecting and reconnecting the USB when it hangs after trying to initialize - but obviously that would not help when it hangs when transferring. Quote Link to comment Share on other sites More sharing options...
Fray Adjacent Posted June 6, 2004 Report Share Posted June 6, 2004 Try uninstalling the software through Add/Remove Programs, then delete the folder under Program Files? Try that, then reinstall. I had problems when I installed Icedtee's version without completely getting rid of what was there before. Also see if you have a lot of TSRs running (lots of crap in your system tray, next to the time at the bottom right of your screen) Quote Link to comment Share on other sites More sharing options...
mmp64 Posted June 6, 2004 Author Report Share Posted June 6, 2004 Thanks. I'll give that a shot. It may also be a USB thing, which I'll also mess around with. Quote Link to comment Share on other sites More sharing options...
Christopher Posted June 6, 2004 Report Share Posted June 6, 2004 If you do uninstall, please do it the way it's prescribed in the NetMD faq [registry edits and all]. Quote Link to comment Share on other sites More sharing options...
