Malow Posted June 5, 2004 Report Share Posted June 5, 2004 hi, i have problems with sonicstage and xp sp2 betas. in fact i belive this is the same problem with sonicstage and windows 2003 server. sonicstage do not create omgkey. the folder remains empty, and on "normal xp", it is created after the fist song added in sonicstage. but with newers betas of sp2 it will crash and the key is not created. (so probably with sp2 final it will not work) any advice? i try to copy the key from other xp install on the same machine, and it let u import the song, but wen need convert to transfer, it crash. any tips? Quote Link to comment Share on other sites More sharing options...
tmeg Posted June 6, 2004 Report Share Posted June 6, 2004 I use the public preview of SP2 on XP and SS2 works good. If this problem persists it might even be a good news as Sony then would have to provide a fix for the problem and then eventually SS2 would work on Server 2003, too. (if these problems are really related) Chris Quote Link to comment Share on other sites More sharing options...
