I recorded my 1st show, now what?
rustedshut
I have a JVC XM-R70SL Mini Disc Recorder and just did my 1st recording tonight and it sounds great thru my headphones on playback.
It came with a TOC Fiber Optic cable for tranfering the files but without this out connection on my pc, Im wondering what my options are to get my music off the md to burn to cd. Any help is much appreciated.
thanks.
Heath
Hi rusted. :happy:
I recommend you try searching first, as this has been discussed in the past under some slightly different circumstances. Basically, though..you'll need a device with optical out [which your unit does not have] - this feature is common on MD decks and bookshelf systems [some around $100usd on eBay]. You could do an analog configuration for now via a male-to-male analog stereo cable [$5 at your local electronics store, usually] via the headphone out on your unit [i recommend the maximum volume] and the mic-in on your computer. Use a program to facilitate the recording and you'll be set [search for relevant programs].
