Uninstalling (for REAL!) Simple Burner 2.0 ?
skinn
Hi there. After installing Simple Burner 2.0 and acknowledging it doesn't work on my PC (probably conflicts) I uninstalled it in order to reinstall Simple Burner 1, but I keep getting the message "a newer version is already present, you don't need to install this one". But there is NO newer version there, 'cause I uninstalled it earlier! Proof of it, if I choose the option "update", it tells me that NetMD Simple Burner is NOT installed, therefore it cannot update it. There must be some hidden file which tricks it into it, but I don't know which one, any ideas, any help ?
Thanks in advance
