which deck to record MDLP mode?
casemd
I have had a portable MD for a while. My last one has MDLP capability and I love the fact that I have 5 CDs on one MD! However, in order to record I always have to use my PC. What I am looking for is the option to record direclty from my CD-changer (an older 50 disc model but with optical out) to MDs in LP format. I love to make random discs from my changer by running it in shuffle mode through 50 CDs. I think this player would be able to help me make random MDLP discs; Sony MDS-JE480
http://ecoustics.pricegrabber.com/search_g...masterid=860177
for $144-ish
Do you think that would work or do you guys have a better idea? Thanks!
Thanks for the quick reply. If I can record using the optical in/out I think the track info is automatically recorded too, right? On my older player, not in LP mode, if I would record using optical it did also add the track info. Other than the link I added, are there any good US sources for any of the other players? Thanks again.
