iceeedtea's SS2 not installing drivers
DomConway
Just installed SS2 (from http://www.minidisc.org/download/ss20e/) on a brand new machine, then hooked up my MZ-N1 and it's only being recognised as "unknown USB device". So it doesn't look like SS2 installed the drivers, which I thought it was supposed to?? Not had a chance to install the drivers seperately, will do so this evening, but was wondering why this might have happened?
Turns out it was a bit of a false alarm - the problem was with my unit, not with SS2/drivers...
I checked the display on the N1 and "PC->MD" wasn't showing as it should have been, and the disc graphic was constantly rotating like it does for a short time when you insert a disk. Took the battery out, left it for ten mins then tried again and all was OK...
