gowally Posted June 11, 2004 Report Share Posted June 11, 2004 i have searched some forums and have not been able to find an answer, so i will try a post and see what happens. My Ojbsir.exe gives me a "cannot connect to the internet" error but i am on a constant connection. Can anyone help? I am using SS2. Quote Link to comment Share on other sites More sharing options...
Christopher Posted June 11, 2004 Report Share Posted June 11, 2004 If you don't get any other recommendations, try uninstalling via the directions in the NetMD FAQ [registry edits and all] and installing again. Make sure you reboot after you install it again! Quote Link to comment Share on other sites More sharing options...
gowally Posted June 11, 2004 Author Report Share Posted June 11, 2004 thanks for the prompt reply but I have already tried that option. Any other help? Quote Link to comment Share on other sites More sharing options...
Christopher Posted June 11, 2004 Report Share Posted June 11, 2004 You did the registry edits and uninstalled everything and then installed the software again? If you uninstalled exactly the way it states in the NetMD faq and install it again you should be fine. I'll see what else I can dig up, otherwise.. Quote Link to comment Share on other sites More sharing options...
