SS2 back up problems
priley
Whenver I try to back up my music files the program loads, checks available disk space then generates an error report and shuts down. I read in the help files that I should only use a Viao computer when backing up files...
"Note
When backing up SonicStage data to a removable media, note the following:
Use a Sony VAIO series computer with SonicStage Backup Tool pre-installed. Otherwise, you will require a program that can write to CD-R/CD-RW, DVD+RW, or DVD-R/DVD-RW discs using the "packet-writing" method."
OR could it be that I don't have Access softwear installed??
Everything else works fine!!
Thanks for any help on this matter
