"missing or corrupt database file" for sonic stage
Guest bikemaker
Guest bikemaker
ok this is my problem recently whenever I use sonic stage (1.0 or 1.5 or 2.0) whenever i open sonic stage i get the message"missing or corrupt database file", so i re-install , (the proper way), and i still get the same problem, so i use administative tools to repair the file, yet still the same problem, so i try using realone player as an file transferring alternative yet i get ANOTHER problem stating that "there either isn;t sufficient space(which there is) or you have the wrong file type" and i do believe i haev the same file type (.mp3), anyone have similiar problems or even a solution if possible?
Guest bikemaker
at least i'm not alone, i have an aiwa am-nx9 , i'm sur emost of your know that aiwa is a company owned by sony, the problem with it is that no other tranfer programs such as real player or windows media player can support it for transferring which is why i cannot fix this problem, also aiwa has no support , this is pissing me off, so much.....soo so much
A wise man told me that you may have not restarted after the installation [or you didn't do the registry deletions when you uninstalled and installed again]. Make sure if you did do a bunch of installations/reinstallations/whatever that you uninstall EVERYTHING as prescribed in the NetMD faq and install Sonicstage 2 only.
Also, if none of that applies to you, please download this file, reboot, and try again.
p.s. If you're not running Windows XP, just search the site for the same file relevant to your O/S.
