Has anyone added digital outs to a portable?
I tried doing a search but didn't really find any info.
I do recording for film/video and I would like to use a MD for this and I was wondering if any of the portables (newer for the better sound) can be modded for coax or optical... I know it would be a pretty hack job do to the size but I don't mind... and I don't mind working on such small parts, I have quite a bit of experience soldering. I even have a digital scope meter but I don't even know where to begin looking for the sources... not to mention I personally don't own a MD yet.
My last resort is to buy(ebay) a mds je330 and hack in a coax output to it since I have coax in on my PC already... does anyone see a problem with this approach... is this one of the models that have loader problems?
Sorry for the newbie questions but I'm pretty new to MD and I want to try and get this right the first time wink.gif
Thanks in advance,
Bogus¹
Welcome. :happy:
I think that modding a portable unit in this sense would be quite a difficult task and probably not worth it, but don't let me stop you!
Why don't you just scout a deck on eBay with the appropriate I/O's you're looking for? IIRC, there are decks with what you're looking for, and they aren't too expensive.
That is an option... though I would probably opt for cheap as possible due to the "independent" (read LOW budget) nature of these projects. That might require me to get the cheaper deck and mod it for coax ...and I think *most* of the decks offer optical vs coax. I have coax so I might as well use that vs converting or adding another card to my pc.
I would think the only difficulty in doing the mod to a portable vs deck is just size of componets and for the folks that like it neat it would be hard to do with out some frankenstien looking results. I don't mind the tiny circuits (if I'm told which to tap into) and I definately don't care if this thing is ugly or not.
Thanks for the advice though,
Bogus¹
  • 2 months later...
