Sony MDS-302: motor for loading-drive does not work
Medra
Hi,
I have a problem with my Sony MDS-302.
The motor for the loading-chassis does not work. The motor itselv is ok, it works if I use an external Power unit (I took 5V).
Could it be possible to solve the problem with a "global system reset" ? And how to do this ?
Or could there be a problem with the motor driver IC ?
Very thanx for your help, I hope I will get it run ;-)
Greetz,
medra
PS: Sorry for bad english, I am german rolleyes.gif
Hi,
hmmm, that page I found before, but no repair info about my problem or a service manuel ...
Btw: My first MiniDisk Recorder was (and is :grin: ) a Sharp MD MT15.
Any other info how to get the Loading-Motor run ?
Greetz
medra
Otherwise ...
does anybody know on which pin to get the signals for eject and for loading ?
I think I could ask the "eject"-switch and the switch on the loading-unit for the loading-signal, but there are other things ...
I think (I don´t know because I got it for 10€ broken from ebay) that it puts out the MiniDisk when it is turned off ... and perhaps generate other Signals for ejecting the MD.
What I plan is that if I do not succeed in repairing the problem I will put an Atmel AVR 90s... microcontroller in the player to catch the signals and to generate the Signal for the loading/ejection - Motor ;-)
Now it works with an external Power supply, but this manual handling is not so good. Later it shall work in my Stereo ;-)
Greetings,
medra
btw: Does anybody have experiance in adjusting the Laser power ? When CD-Players will not work you can adjust the decreased laser power by a potentiometer...
In the service-menue there is a Menuepoint named Laser Power Adjustment. Does anybody have experience with it ? I have probs with an older MD (which is played by my Sharp portable without probs).
