Which netMD player? Replacing 707.
u2o
Hi all, first post here and glad to come across from google search.
I'm looking for a new netMD player, my N707 gave up on me completely after 3 out of 4 screws holding the front panel disappeared, warranty didnt cover and now its eqpired. Front panel is really loose, and my earphone plug bit is now mysteriously damaged, i have to keep pressure on it to get the sound out from both ears.
So after a short life of 1 year 6 months its time for a change unfortunately. Shame coz i quite liked this MD player.
I looked at N710, but I heard about some low power of sound? Whats that like compared to my 707? I have a low budget of approx. £130, N710 could be purchased at this cost. But im goin to Japan next week, i looked at their prices and N10 is sold for approx. £150 (i could stretch my budget to this if its REALLY worth it).
I shall also visit Tottenham Court Road, London next friday. Any bargains to be had there that might be useful?
So what are my best chances?
Thanks all.
u2o
Hi. Yes, I'd avoid the N710 if I were you, at least if bought in this country. The Japanese one would be a fine replacement for your N707 though, if you can wait till you're there.
There are several places on Tottenham Court Road that sell the Sharp IM-DR420, eg. Gultronics. I'd highly recommend this nifty recorder - it's not pretty but more than makes up for that in features, and would be even louder than your N707.
There are other variants of the DR420 - eg. the DR410 which is the same but has no mic input, or the DR370 which also is non-NetMD.
Thanks KJ,
I'll definately consider that SHARP DR420 as well in that case. I'm not quite sure about the remote though, I want a display on my one.
I had a SHARP md ages ago, and that lasted a good chunk of years so i'll definately think they're reliable.
I shall avoid 710 in this country, I looked at japanese store websites and couldnt find 710 on their list but I may just go for N10.
