shin Posted July 4, 2004 Report Share Posted July 4, 2004 Hi, I'm trying to record MD with a chaintech AV710 optical output (1.30a driver), using a non-netMD. I can record this, but my MD don't recognize the track marks. I'm trying to use winamp (ASIO4ALL), foobar2000 (kernel, asio) and gaps of 2~7 secons but without results. someone can help me? ps: i don't speak english. sorry by my errors of writing. Quote Link to comment Share on other sites More sharing options...
skyther Posted July 4, 2004 Report Share Posted July 4, 2004 Mute all sources except wave and main under Windows' Volume Control. Quote Link to comment Share on other sites More sharing options...
shin Posted July 4, 2004 Author Report Share Posted July 4, 2004 Mute all sources except wave and main under Windows' Volume Control.no results my MD is part of a japanese combo, with a cd player with digital output and md player/record with digital input. This combo works fine with track marks. But don't work with optical out of AV710.. =( Quote Link to comment Share on other sites More sharing options...
Christopher Posted July 5, 2004 Report Share Posted July 5, 2004 Get rid of that driver and download this: http://www.viaarena.com/?PageID=327 Welcome to the forums, btw. :happy: Quote Link to comment Share on other sites More sharing options...
shin Posted July 5, 2004 Author Report Share Posted July 5, 2004 Get rid of that driver and download this: http://www.viaarena.com/?PageID=327 Welcome to the forums, btw. :happy:sorry. my installed driver is the 3.10a, not 1.30a... i think that my md recorder uses another detection type of track marks, different of silence mechanism it's possible? using the combo (CD+MD), if I pause or stop the cd player, the MD don't stop record. But if I change the track, MD automatically make track mark and continues recording. is there a any way to send this signal type via soundcard? Quote Link to comment Share on other sites More sharing options...
Christopher Posted July 6, 2004 Report Share Posted July 6, 2004 IF you don't have any luck here, I suggest you go to head-fi.org/forums and inquire there. Be sure to report back with the answer for others who may experience the same issue.. Quote Link to comment Share on other sites More sharing options...
sovereignty Posted July 25, 2004 Report Share Posted July 25, 2004 I am using Chaintech AV710 optical output to record MD in my MD deck JB930 and it just works fine. I also use the 3.10a driver and foobar2000 as the player. Be sure to select the "normal 2 channel stereo mode" in the driver audio deck. The natural interval between songs automatical set the track. Quote Link to comment Share on other sites More sharing options...
