mz n10 charging problem
sungshintai
my mz n10 won't charge, i can charge it overnight and the next morning it will still say "low batt" and turn itself off. the dry battery pack also does not work.
ive got no idea what is wrong as the unit was working perfectly fine. if it helps i am using a japanese model.
thanks for any help.
i also have a charging problem. i have a sharp md from japan and i can't seem to charge the battery. i even bought a new battery for it. i've never had this problem before. i did plug it into the wrong voltage outlet while i was traveling, but when i brought it home it was still working, it's just that the ac adaptor wasn't. i bought a new adaptor that appears to work, when i try and charge it the lights for charging are on, but it never gets charged.
I don't know if this will help, but if you're not using a voltage adapter for Japanese electronics on 120V house current you may have damaged your units.
Since Japanese house current is 100V @ 60Hz, it's close enough that Japanese units will work on US house current (120V @ 60Hz) but I've heard that some people have had Japanese electronics that were damaged by being used on 120V without a converter.
Conversely, the Li-Ion battery in your MZ-N10 may have reached the end of its useful life, in which case you'll need a new one.
