Webmaster Posted July 5, 2004 Report Share Posted July 5, 2004 [submitted by Duane Galensky after reading the MZ-NH900 manual] 1) the 1GB discs and linear PCM coding use the most power (3.5 hours per charge for continuous recording). 1GB disc and NiMH plus singe AA cell records for 8.5 hours non-stop. 2) using the supplied AA battery box plus the NiMH stick, a regular MD using hi quality ATRAC3plus coding will record 12.5 hours on one charge + one alkaline AA cell 3) there are two limiter knee settings called "Mic AGC" - standard (for 'soft music') and LoudMusic (I guess for a live band with a PA). LoudMusic it seems has the greater potential for that undesirable breathing effect. But maybe the softer knee standard setting will eliminate the need for setting levels manually for recording acoustic music. Note you still have to go into the menus and re-select manual recording levels every time you hit Stop (Pause preserves the setting, Stop reverts to Mic AGC) I hate that. 4) there is also an independent mic sensitivity setting that might make AGC more usable 5) linear PCM gives 28 minutes record time on an 80 minute disc and 94 minutes on a HiMD disc 6) hi quality ATRAC3plus gives 2 1/3 hours on an 80 minute disc and almost eight hours on a HiMD disc=20 7) it can record in the existing disc format for playback compatibility with existing mini disc units (but who would want to do that) 8) it has integral 6 band EQ 9) not sure how to go ATRAC to PCM so may have to record linear to take advantage of USB transfer to PC for subsequent splitting into tracks and mastering of a live recording to CD So the net of the battery life and the disc capacity is that you can carry either one blank 1GB disc, one fully charged NiMH plus one AA in the battery box and record eight hours on location, or if you prefer, pack five regular MDs (the 80 min type) for the same battery complement and record about twelve hours without needing a charger or AA battery change. If forced to record PCM it's about four 1GB discs per charge + one AA alkaline for eight hours recording. Quote Link to comment Share on other sites More sharing options...
