Guest Ascariss Posted July 8, 2004 Report Share Posted July 8, 2004 Contuation of this thread: http://forums.minidisc.org/viewtopic.php?t=5186 I have a question to users of the the MZ-N10, when you attach the extra battery pack, should the remaining battery power go up? Next inside the battery pack, it says this, dry battary use is not possible if the built in battery rechargeable battery is exhausted. Is this true? I am taking to back to the store to see what they can do, but it was the last unit they had in stock so I am not sure what I can do. I am not sure if this is the internal battery that is broken or the battery pack, but it charges fine and the internal battery works fine. If the store where I bought can't do anything I have to take it to sony. Quote Link to comment Share on other sites More sharing options...
Guest Ascariss Posted July 8, 2004 Report Share Posted July 8, 2004 I don't get it, now it works, after the internal battery is on its last segment. I will never understand sony, and their crazy engineers. Quote Link to comment Share on other sites More sharing options...
highlandsun Posted July 9, 2004 Report Share Posted July 9, 2004 The MZ-N10 only uses one battery at a time, and the battery level indicator only shows the state of the currently selected battery. So if you attach the external battery the battery gauge may or may not change, depending on whether the N10 decides to switch to the external, or continues to use the internal. Quote Link to comment Share on other sites More sharing options...
