recording levels
johnny86
i use a sony mz-g750 md recorder with a sony ecm-ms907 microphone to record my orchestra and band concerts. I have the md recorder set so it changes the recording level automatically.
However, when the music is loud, the mic+md seem to not be able to cope and the sound is really bad. Is this because the levels can't be changed much?
Should I set the recording level myself? - i play in the orchestra, so during the recording i cannot change the levels.
Any ideas how to get a better quality sound?
Ps- the bands are very very loud, and we play in a very echoey concert hall!
Cheers
John
don't use auto levels EVER... unless its for voice....
the best way is to try a few settings, and see what happens. make note of what level you used, and listen to the results. you'll get it after a few times.
another way would be to get a batt box that will increase the dynamic handling of the mics. but that requires more $$.
The Radio Shack headphone volume control will also cut the incoming sound to appropriate levels--a volume knob on a cord--$6.59. Turn the knob all the way UP for all but the loudest shows. Easier to carry than a battery box, and the resulting recording is louder, with a slight loss of fullness.
  Quote
will this do the same as turning the recording level down via manual volume control?
im just asking cause ive been recoding in v loud clubs and i get some distortion. ive been using the auto level setting, so im not sure if its the microphones fault or im recording too loud for the md.
You could be either a) overdriving the mic [exceeding it's max. SPL] or cool.gif overdriving the mic input [which doesn't have a lot of headroom on portables like MDs].
If you're using a MS907 then a battery box won't help you since it's only powered by its internal battery. [***I might actually be wrong on this, some mics of this type can detect external power and bypass their own battery in favour of it, but I haven't known the 907 to do this, and I've used them a lot]
If the problem isn't that the mic is being overdriven [and is that the mic preamp is] then an external preamp would likely fix your problem. Most external preamps are also battery boxes, and include gain and/or level controls. Sound Professionals have a very decent portable preamp that runs off one 9V battery and plugs into the line-in on your MD, skipping the [clipping] mic preamp altogether. The line-in has a lot more headroom.
