limax Posted July 10, 2004 Report Share Posted July 10, 2004 Rather than use my sony minidisc MZ 700 +AKgGmicrophone set up to input direct to my PC and sound forge stuff, I think there would be an advantage to using a deck minidisc player like the Sony JE 530 or JB 930? Any advice gratefully received. I tend to record at 4x (my my hearing- no loss of quality over normal speed given the sort of live stuff i'm listening to!) .. can either/ both these decks play back x4 discs? Many thanks, Neil (UK) Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted July 10, 2004 Report Share Posted July 10, 2004 Hmm, LP4? Then start with the JE640 or the JB940 or younger. JE530 and JB930 cannot play LP4. I suggest, you look here and then buy accordingly: http://www.minidisc.org/deck_table.html Look for MDLP. Unless your soundcard doesn't have digital in, the deck should have digital out as well, as that improves the soundquality. Oh, and a home deck makes editing much easier as well. Quote Link to comment Share on other sites More sharing options...
Christopher Posted July 10, 2004 Report Share Posted July 10, 2004 Stating your maximum budget and location will help us aide you, too. :happy: Welcome! Quote Link to comment Share on other sites More sharing options...
limax Posted July 12, 2004 Author Report Share Posted July 12, 2004 Thanks for the fast advice, have gone for a JB 940 as you suggested. Have an audiophile 2496 card in my PC. Neil Quote Link to comment Share on other sites More sharing options...
