Bassoon Posted July 14, 2004 Report Share Posted July 14, 2004 I managed to loose my original Sony Net MD install CD so now I can't install it on my new computer. Is it possible to download everything that is on original disc that comes with Sony Net MD MZ N1. I need it really bad. Thank you very much Dejan Quote Link to comment Share on other sites More sharing options...
borishnakov Posted July 14, 2004 Report Share Posted July 14, 2004 if you look hard enough some hacker or cracker or regular website could have them to download! or if you have msn i could send them... but i'm not that nice! Quote Link to comment Share on other sites More sharing options...
iceeedtea Posted July 14, 2004 Report Share Posted July 14, 2004 Quote if you look hard enough some hacker or cracker or regular website could have them to download! or if you have msn i could send them...I laugh at your improper use of terminology. :laugh: Quote but i'm not that nice!Then why reply to the thread in the first place? Useless post +1, ne? The contents of the MZ-N1 disc are outdated. Go download SonicStage 2.0 from Sony Connect which also contains the drivers that you requested instead. Unofficial drivers-only installer, by the way. Should be the same as what is packed with SonicStage 2.0 from Connect. So use the Connect.com installer. Quote Link to comment Share on other sites More sharing options...
Bassoon Posted July 15, 2004 Author Report Share Posted July 15, 2004 Thank you for your kind help Dejan Quote Link to comment Share on other sites More sharing options...
