Tiesto Posted July 15, 2004 Report Share Posted July 15, 2004 Hi there, I read some topics about how some people is unable to transfer some mp3 files to their devices. Well, it happened to me as well. However, I found out a way (kinda extreme though). I don't know if this issue has been solved already, but here it goes anyway: I have Cool Edit pro installed on my laptop, so if there is any mp3 file that SS2 doesn't recognize then I open that file with CoolEdit and save it again at the same bit rate. Now, I "re-import" the file to the SS2 library and LISTO! you can transfer it. p.d. I haven't proved with MMJ or another mp3 converter Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted July 15, 2004 Report Share Posted July 15, 2004 Well, what you are doing, is reencoding the file again, introducing additional artefacts. Save it with higher bitrate under a new filename and don't overwrite the original file. Quote Link to comment Share on other sites More sharing options...
Tiesto Posted July 15, 2004 Author Report Share Posted July 15, 2004 Well, what you are doing, is reencoding the file again, introducing additional artefacts. Save it with higher bitrate under a new filename and don't overwrite the original file.I keep the same bit rate. The file name is up to you... it does work for me. :smile: Quote Link to comment Share on other sites More sharing options...
