compatibility with editing software eg Adobe Audition
Not as such. You can't take the uploaded file out of Sonicstage or the secured, unplayable OMG format so the only remotely viable seeming way is to set Sonicstage playing the uploaded file, and use Cool Edit to record the WAV output in real time (if your soundcard supports it).
The thing is that many soundcards will only enable you to record the analogue mix of the WAV out, making it not significantly better than sticking your Hi-MD's headphone/line output into your soundcard, playing about with levels, etc. A far from satisfactory solution.
