bigal Posted July 17, 2004 Report Share Posted July 17, 2004 Hi everyone - new member bigal here. I have a large music collection on Audio CD's. These were copied from the originals using my standalone Pioneer PDR509 CD recorder. Although the Pioneer unit has optical in/out I have always used conventional phono jack leads when recording as the source has no optical out - which I guess means that the method I have used is analogue? (or digital coaxial?) Anyway, I recently purchased a Sony MZ-N710 NetMD portable believing that I would be able to copy these copied (analogue) CD's onto my PC then directly onto the MD using the software and leads supplied. How wrong I was as you all well know. Anyway - as a compromise I now want to try and copy these CD's from my Pioneer PDR standalone via optical cable to my NetMD portable at LP2. What I need to know is if the portable will auto track number because I am using the optical cable? Quote Link to comment Share on other sites More sharing options...
Christopher Posted July 20, 2004 Report Share Posted July 20, 2004 Welcome, bigal. This should work, but there is no harm in trying. Most digital connections like this work do well with trackmarking [at least in my experiences]. Quote Link to comment Share on other sites More sharing options...
Mat Posted July 21, 2004 Report Share Posted July 21, 2004 Just make sure to set it on syncro rec! Quote Link to comment Share on other sites More sharing options...
