need help....
jamesj
hello, im new to the forums and well i have some questions on minidisk players, im looking to buy one and well about a month ago i was able to purchase a sound blaster audigy platinum sound card and it came with a program called creative minidisk center and from what i am able to read i can use that to upload my music to my player is this correct? and my next question is i would be able to use the optical in/out cable on the audigy drive right? see i have not yet purchased a player yet and i am lloking for a fairly cheap one i can use at work and around the house. and well the ones i was looking at is the sony psyc and sony net md players but as i was reading i saw that some models come with digital inputs and outputs, is this the player that i will need to use this program? or am i going to have to buy a more expensive player? if you can help me out i would greatly appreciate it alot thank you all....also what is a toslink cable? thanx again
All NetMD / HiMD-recorders from Sony come with it's own software called SonicStage, which allows faster download onto MD.
Realtime recording from the Soundcard is possible as well, via Lineout or Digital out.
Having a recorder with Line-In/Digital in has the advantage, that you can record from other sources as well, allowing to copy stuff without a computer.
In that case, the Creative program helps you in assembling of your playlist.
A toslink cable is an optical cable with a rectangular plug on one side and a 3.5mm- plastic plug on the other end.
Most MD-recorders have one included, the rectangular one goes into the soundcard, the one, where the red light shines out.
My personal choice for the biggest versatility, if you can wait a few weeks is the MZ-NHF800. It has a radio, can record from microphone and your regular stereo and can store more music on the disc. Plus, it can use the new 1GB discs for even more music in addition to the normal ones. And it doubles as a backup-drive for your computer as well.
See here:
http://www.minidisc.org/part_Sony_MZ-NHF800.html
A good place to look:
Minidisco
