sonicstage problems 100% cpu usage
matrix787
Do this:
How to properly reinstall NetMD:
WARNING: If you use a Sony VAIO with preinstalled software provided by Sony or use other software developed by Sony, do not follow the procedure below.
1. Uninstall all OpenMG related software via the Add/Remove Programs control panel and reboot as necessary. This includes, but is not limited to, OpenMG 2.2, related 'Limited Patches' and the 'Secure Module', SonicStage 1.x/2.x, Simple Burner 1.x/2.x, and software by RealNetworks. Make sure that you unplug your unit before doing so.
2. If you run Windows XP/Windows 2000 Professional, proceed to delete the following directories: "Documents and SettingsAll UsersApplication DataSony Corporation", "Program FilesCommon FilesSony Shared", "Program FilesSony".
3. Start -> Run -> regedit. The 'Registry Editor' utility should appear on your screen. Delete the references to OpenMG located under 'HKEY_CURRENT_USERSoftwareSony Corporation' and 'HKEY_LOCAL_MACHINESoftwareSony Corporation' by right-clicking on the entries.
4. Disabling any anti-virus software that is running in the background to free up some resources [if necessary]. Update your installation of Windows at Microsoft Windows Update (windowsupdate.microsoft.com). For Windows 2000 Professional users, you are recommended to upgrade to Service Pack 3 or later. Make sure that your unit is disconnected and install the latest build of SonicStage 2.x from Sony Connect/Sony Connect Europe. The drivers for Sony units will automaticaly be installed. (If you use a Panasonic or Sharp Hi-MD/NetMD unit, install your drivers before you install the actual software!) Restart if prompted to do so; if not, it is still recommended that you do so. Plug in your unit, and start SonicStage 2.x.
..so we can make sure it's not a software issue.
