PCM to PC to CD
Linguini
Dat is 48 kHz, isn't it?
Slightly different version from jadeclaw's, same info really:
Consumer DAT would record in 48kHz ["analogue" mode], 44.1kHz from digital sources minded by SCMS, and 32kHz ["analogue" LP mode] - the point being that the restriction on 44.1kHz recording meant not being able to make copies of things from analogue sources that would be suitable as [2nd-generation] masters. Mind you, that could all be easily circumvented with a sample rate convertor or external A/D.
Master tapes over the past 20+ years have generally been 44.1/16.
