xitel MD-Port I/O
classicalnut
The Xitel dongle uploads via an analog connection, so it's going to take a quality hit, but unless you have a MD deck, it could work well for you.
If you have a decent sound card, I'd just plug your MD into the line-in jack on your sound card and record from source (line-in). This is what I've always done with my live recordings, and since I spent some money on a good line cable, I can't really tell differences that much and neither could the bands I recorded demos for.
Also, if you go that way, you don't have to buy the Xitel. :happy:
  • 3 weeks later...
I use an Xitel I/O Port. It works great. There may be a loss of quality but you will loose quality with any analog connection. I do not have a sound card with an audio in so I got the Xitel I/O port. I really like it and would suggest getting one if you do not have an audio in on your sound card.
