WHICH MD TO USE FOR BACKING TRACKS??
Shadowplayer
I just stumbled onto this site (thank God) and I need some advice. I play drums in a touring band that uses MD to run backing drum loops, extra guitars, effects, etc. I run it from behind my kit with a click sent on the Left channel and the music sent to the Right.
I've been using a Sony MDS-JE330 for this. I know this model is supposed to be used for home use, which is why after a couple of months it starts skipping. Because of the wear and tear of load-in and load-out.
I need recommendations on what I should REALLY be using. It needs to be rackmountable obviously. I made some custom rack ears for the one now. I need a sturdy and reliable player that won't break my bank account as well. So glad I found this forum! Thanks in advance for your advice!
I would say:
Sony MDS-E12:
http://www.minidisc.org/part_Sony_MDS-E12.html
Special Feature: 10 Hotstarts, that can be played with a touch of a button without delay.
Tascam MD-350:
http://www.minidisc.org/part_Tascam_MD-350.html
Or if you finally decide against rackmount, the HHB MDP-500:
http://www.minidisc.org/part_HHB_MDP-500.html
Since these are pro units, designed for heavy duty use, they should last a lot longer than a JE330.
Plus, you get XLR-balanced connectors, which make interfacing with other professional equipment much easier...
  • 3 months later...
