verbal Posted August 18, 2004 Report Share Posted August 18, 2004 I bought a medium size Otterbox 2000. Fits my MZ-N1 perfectly! I modified it by drilling two holes on the bottom near the hinges to hold my Sound Professional binaural mics. The drill bit I found is just the right size of the mics. The mic slips right into the hole. I with it was a little smaller for a snugger fit, but it's still good. I need a little help though. When I was testing it out by recording while walking around the house with it. The mics easily pick up the wind from my arm swinging. So I need to figure out something to stop this. I could cut up a windscreen and glue it in there, but the hole is only a little over a quarter of an inch. It would be hard to manuver and glue in there. I don't want to glue it outside cause it'll be too obvious. Any ideas? Also, the mics are a little loose in there. If the case it bumped the wrong way one could fall out of the hole. Any ideas on how to keep them in place without tape or anything that could damage the mic? Quote Link to comment Share on other sites More sharing options...
