Mark H Posted August 18, 2004 Report Share Posted August 18, 2004 I usually record on my portable DAT then play through my Mac via line in and record onto Logic for editing. Will I lose any sound quality if I switch to HI MD and record uncompressed? ie not using ATRAC. I've read through all the bumph but it still seems unclear. although I suspect that Hi MD uncompressed is exactly the same as DAT. Any opinions? Mark H Quote Link to comment Share on other sites More sharing options...
Markr041 Posted August 18, 2004 Report Share Posted August 18, 2004 I have used DAT tapes. It is a pleasure to use discs instead of tape. The PCM setting is 44MHz, 16-bit. DAT records at 48MHz, 16 bit. That should make no difference. If you used Windows, you would have the capability with Sonic Stage/Total Recorder to get the data into an editor as a wave file without any digital analog conversion. That is a big advantage over DAT - which required a DAT machine with digital out and a computer with digital in. You are certainly losing something by converting to analog and the re-converting to digital. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted August 19, 2004 Report Share Posted August 19, 2004 For analogue transfers - as long as you use a model with an actual line-out on it, I wouldn't think you'd find any signficant difference, no. Your portable DAT might have better mic preamps and such in it, though. Quote Link to comment Share on other sites More sharing options...
