Using a NH-14WM and AA at the same time.
Mat
If using both the rechargeable & the AA case at the same time, will the recorder (N1 in this case) will drain power from both sources, or use up one of them first?
The N1 uses the NiMH gumstick battery, so... it will indeed drain both the AA and the NiMH at the same time.
Only the Sony MD units with Li-Ion batteries drain the AA first and then the rechargeable.
Hmmm... well the N10 uses the Li-ion first actually, but doesn't completely drain it, then it uses the AA, only using that little bit energy in the Li-ion for firing up the N10 from it's off state, hence the N10 not starting with a full AA and a flat Li-ion. Sorry thread digression and excessively long sentence.
