Help with finding Sonic Stage 2
Jolae
Hi, i am fan of your site, i have two minidisc MZ-R700 and MZ-N505 (looking for new Hi-MD 700 series:))
I downloaded instalator from www.connect.com, installed it but its version 2.0.06 16140
i heard that there is version 2.1 fixing many problems....
I selected united Kingdom on site...
Anybody could help me?
Thanx in advance and mainly sorry for my English
I LOVE THIS FORUM!!
Not a bad unit. A little feature restricted, but most likely will leave a good impression for those who are delving into Hi-MD. I myself would get a NH900 over this unit, but if your budget is absolutely limited to the NH700 then I'm sure you'll be fine if that's what you end up getting.
What would your primary use of Hi-MD be? :happy:
  Quote
Maybe it sounds crazy but i will use it like portable "disk" (i am downloading a gigas of mp3s) so i will record maaany albums to one Hi-MD disc and recording from optical sources....
But the main problem in my country when i live now is that sellers have only normal MD mediums, not Hi-MD...how many costs Hi-MD in your country? or in dollars?
TIA
and THX
