MZN-10 Problems
Ultimo
I have had my MZN10 for almost a year now and this is the first problem that I've had.
When i put the MD on the cradle it doesn't come up with PC-->MD as it should, but when i take it off the cradle only then does PC-->MD show up on the display. I have tried it on 3 different PC's and i still have the same problem.
I hope that someone can help me !?!? :sad:
  Quote
Well yes and no. I had this problem with my N10 a few weeks after I received it (April '03). Anyway there's nothing you can do other than to send off to Sony for fixing it under warrenty, while you're still under it. I've come across this N10 fault quite ofter on various forums that touch on the topic of NetMD players.
Damn.
Sounds like you've got bigger problems than I can fix. :sleep: Almost all of the problems I ever had with my N10 I could fix by flipping the battery switch.
Mostly the same for my other MD recorder: almost all problems I've had with my R900 I could fix by removing the gumstick battery, except for the interesting time where I dropped it from a pretty good height and something inside, perhaps the optical-pick up block, got knocked out of alignment and the unit refused to play. A friend of mine fixed it; works still even after almost four years of very hard use.
Sorry it didn't work.
