Kirk_drummer Posted September 2, 2004 Report Share Posted September 2, 2004 Hello all, This is my first post and I did try and find the answer out there on the FAQ site. Can I record ATRAC files to a CD for storage and load them to my player straight from the CD? Or import them from the CD? What I am trying to do is to just have my collection of songs on a CD to load up when ever I want. Does the format the portable CD players match the minidisc Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted September 2, 2004 Report Share Posted September 2, 2004 If you're using SonicStage you can write ATRAC3 / ATRAC3+ CDs, yes. They are data CDs in the same way that MP3-CDs are. I'm not sure what happens to the DRM info when you do this, though, as I haven't tested it myself. Hopefully it's possible to re-import the tracks from CD at a later date and still be able to write them to MD without restrictions being imposed. I'm assuming that as long as the same computer [correction - same install of SS] is used, this should be possible. Quote Link to comment Share on other sites More sharing options...
[StrangeByte] Posted September 3, 2004 Report Share Posted September 3, 2004 Quote I'm assuming that as long as the same computer [correction - same install of SS] is used, this should be possible.sounds good... but i'm afraid that when you delete the tracks all the drm info on the hd is lost and you can't re-import them (though i haven't tried this with ss but made some similar experiences with openmg jukebox 1.0) Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted September 3, 2004 Report Share Posted September 3, 2004 Quote "]sounds good... but i'm afraid that when you delete the tracks all the drm info on the hd is lost and you can't re-import them (though i haven't tried this with ss but made some similar experiences with openmg jukebox 1.0)I have no experience with OpenMG jukebox, nor with most features of NetMD as opposed to HiMD which I am now using. SonicStage might work differently though. We need an expert on the differences, here, which I'm not. Kurisu? Anyone? Quote Link to comment Share on other sites More sharing options...
