Recording on MZ-S1?
Korgull
First you'll need a microphone. Make sure it has a stereo plug (two bands around the prong, like the one in the pic under my signature) and not a mono plug, with one band.
A Mic-In jack has a built-in preamp, a Line-In doesn't. To record through a mic via Line-In means you need both a mic and an external preamp, which is likely to be expensive unless you get lucky on Ebay or something. For the price of a preamp, you can probably find a good used MD with a mic jack.
